Evo on 2 cylinders? Help Please?
L
lynnsy
Hi im new to this forum.
Have a Evo 7 and recently lost power to one coil pack. I went got another coil pack which didnt cure the problem.
Im thinking ECU (standard ECU)
Help appreciated
Pic of my evo anyways
Mmmm white VII
Welcome along
You did replace the one that was faulty didn't you?
Won't be the ecu. Most likely a connection or relay. Fuse box under the bonnet.
Flash codes out by shorting pin 1+4 on obd port
L
lynnsy
Cheers for the comments guys.
Were do these codes flash up????
Yea I know have three coil packs, they all work on the passenger side. The drivers side coil pack can be unplugged and car still runs the same..........
evo arm's m7960
evo arm's m7960
there should be a live a earth and a signal wire to each coil . compare the working side to the non working side and work back from there . could be as simple as broken wire .
