Evo ix 360 acd lights
muddsy
llanelli
Hi all i`m new to this site so bear with me lol, I`ve been having issues with my evo ix 360,a few days ago whilst i was driving it the three acd lights came on i thought it was strange so i stopped cycled the ignition and then only the selected light came on so i thought all was well obvously not! then the next time i drove it the three lights came on and after cycling the ignition again they would come back on after a few mins,then yesterday when i took it out to try it didnt do it i only had the one light on:hm:
I`ve checked the level of the diff oil in the boot and it`s fine so i`m looking for any suggestions
Thanks all
You need to get the fault code. Use a small piece of wire into port 1 and the other into number 4 of the on board diagnostics port and turn the ignition on and count the flashes from the acd lights. Long flashes are tens the short ones are units :)
muddsy
llanelli
Thanks for that,where is that socket? i`ve looked under the dash behind the coin draw by the fuses and can only see two small plugs with 4 contacts in each...is this the one?
