jay2k6
- Wrexham
Just wondering if someone can explain this for me, I've lost all compression (and I mean all big fat 0 lol) due to a damaged valve, so stripped it down and only the cam belt to go.
But this is doing my head in, because of the screw driver going into oil plug at the front of engine. I'm putting all the timing marks where they should, cams, crank, balance shift top sprocket and oil sprocket but can't get the screw in, only goes about 10mm but if I turn it forward 4 teeth, then screw goes all the way, about a good 80mm
So what's the crack here as I don't want the balance shift to be out of timing and have to do it again, got enough problems because of a bloody spark plug :cry
Thanks NGK:whistling
So is it already out, or am I missing something that is right in front of me lol
Thanks in advance peeps
