evo 4 over fueling
A
andrew
hi there i have a evo 4 that is over fueling when its warm but when its cold it is fine to drive have had it on a scan tool and its all fine apart from the injectors staying open to long when it is warm there are no codes coming up can anyone help
Have you checked afr's?
How do you know it's over fuelling?
What mods on the car?
A
andrew
afr is fine o2 is reading fine. Everything is working as it should when you have it running with the scan tool plugged in apart from the injector pulse, you can see it staying open too long. Car has forged pistons rods and crank. Balance shafts removed and has a gt35 turbo.
You maxing the injectors out. Bigger injectors required...
K
kenchenzo
yeh agree you need larger injectors your pushing them to hard
A
andrew
car only running 6psi as i am still running it in and it ran well with this turbo set up before i pulled the motor out and forged it don't know the idc readings
