P
peanut651
hey people. basically my evo1 has been sitting for a few weeks with a flat battery. i opened the door by turning the key, opened the bonnet and hooked up some jump leads. try and start it and it doesnt turn over.
it also has a wierd alarm system in where there is a seperate small fob on the keyring which i have to push and hold into a little slot in the dash untill a small red LEd turns off, when the light turns off i can then put the key in the ignition and start it. the problem is as soon as i hook up power to the car this small LED stays on constant and doesnt go off when i put the fob it. normally is flashes.
sorry for bad description and i dont even know if this alarm system or imobiliser comes as standard as i said in the welcome section im a complete noob.
any help would be good if there is anythhing i can do to start it
