Clutch Masters Clutch Kits
grant620
grant620
Somerset, UK
Hi Guys,
New in...
Clutch Masters Clutches!
Clutch Masters make a massive range of Clutch Solutions for most makes.
Specifically, for the Lancer EVO, you will be interested in ranging from 400 to over 600lbft on a single plate clutch:
FX100
The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation
FX200
The FX200 System uses the Power Plus I Pressure Plate and a Steel Backed Kevlar disc. This clutch is designed for the street enthusiast or weekend racer. The FX200 offers similar torque rating and holding capacity as the FX100, however, its life expectancy is increased with the Kevlar disc. Our Kevlar friction material is non-abrasive and doesn't score the mating surfaces. It features only slightly increased pedal pressure, significantly longer life than stock, and normal clutch feel during engagement and disengagement for the smoothest operation of any stage we offer. Minimum 500 miles required for break in.
FX250
The FX250 System uses the Power Plus I Pressure Plate and a hybrid combination of Clutch Masters New Formula Button on one side and a heavy-duty Steel Back Organic friction lining on the other. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX250 clutch system has a higher holding capacity than a traditional full faced Kevlar without compromising the street friendly characteristics Clutch Masters is known for.
FX350
The FX350 System uses the Power Plus I Pressure Plate with Clutch Masters New Formula Button disc. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX350 clutch system has a higher holding capacity than a segmented Kevlar lining without compromising the street friendly characteristic Clutch Masters is known for. For year’s enthusiast have had to compromise durability for drivability and vise versa, however with Clutch Masters New Formula button we have closed the gap between these two tradeoffs
FX400
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup and 6-wing being the less aggressive (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more street friendly than solid or rigid designs. This disc is designed for outstanding holding capacity, and rapid heat dissipation. The FX400 ceramic paddle design creates a quick and rapid engagement as well as clutch chatter that may not be ideal for street driven vehicles.
Flywheels:
Chromoly - 5.0kg
One piece with integrated ring gear.
Aluminium - 4.1kg
6061-T6 Aluminium with steel ring gear and steel insert for friction surface
All kits come with release bearing, cover, plate and alignment tool.
Prices:
EVO 4/5/6 with aluminium flywheel
FX100 - 425lbft - £1085
FX200 - 450lbft - £1194
FX250 - 525lbft - £1194
FX350 - 550lbft - £1194
FX400 - 575lbft - £1194
EVO 4/5/6 with steel flywheel
EVO 7/8/9 without flywheel
FX100 - 425+lbft - £715
FX200 - 450lbft - £825
FX250 - 525lbft - £825
FX350 - 550lbft - £825
FX400 - 590lbft - £825
EVO 7/8/9 with aluminium flywheel
FX100 - 450lbft - £1235
FX200 - 500lbft - £1345
FX250 - 575lbft - £1345
FX350 - 600lbft - £1345
FX400 - 620lbft - £1345
EVO 7/8/9 with steel flywheel
FX100 - 450lbft - £1165
FX200 - 500lbft - £1279
FX250 - 575lbft - £1279
FX350 - 600lbft - £1279
FX400 - 620lbft - £1279
All inc VAT and FREE delivery!
