Clunk sound (fronts)
ron23
norwich
I was reading andy's post about having that clunk sound
from the rear when reversing....mine was a bit similar,only
The sound was coming from the fronts specially when reversing
I didn't use the car for 2 weeks,and when I drove it,
It gives this clunk sound...would it be bushes guys?
Thanks
Ron23
andyw08
andyw08
skelmersdale lancashire
Mine was when changing gear mate, is it just one clunk? Could be anything really... Check your gearbox mount bushes and obvious stuff like wishbones
ron23
norwich
Thanks Andy...there is no clunk sound when changing gears...but when
I start to reverse,the sound came to play....but I will definitely check
The other bits...I hope it's not too expensive! Lol
Andy6
Andy6
Liverpool
You need to gove the whole front end a real good check over, It's a bloody nightmare chasing clunks! get a pry bar or something you can use as a lever and go round all the bushs and ball joints do a visual check and try and move them them with your lever. Also try and expose the car to a variety of conditions, I.E going over bumps, with one or both front wheels, on full lock left and right etc. I've also been known to sit on front end, bonnet up and a mate drives it over some bumps!
Have you got standard top mounts ?
ron23
norwich
Yes Andy they were all standards...it's been 5 yrs since I repla
Top mounts and drop links,but failed to sort out the bushs etc
But I will investigate further...thank you for your tips..
Highly appreciated.
