- north east
We are please to be able to offer you the Brembo Range of upgrade replacement discs and pads. I would like to offer the first 5 sets sold with 10% discount to get them into use and some feedback on the forum.
Brembo Sport Brake Discs are designed to fit under the factory wheels and tyres, utilizing the original calipers to provide improved performance and appearance. Brembo Sport Discs offer excellent stopping power in everyday traffic and performance driving. The cross-drilled or slotted systems reduce operating temperatures and fade while improving wet weather performance and initial pad “bite”.
Brembo Sport Discs come complete in a well-presented boxed kit and comprise the following:
1 piece zinc-plated cross-drilled or slotted discs (pair)
High performance brake pads (axle set) (optional extra if available)
Comprehensive fitting instructions
TÜV Certification and Homologation
Mitsuibshi Evo 4-9 Fronts (320mm) £315 (300mm) Rears £300
Mitsubishi Evo X Fronts (350mm) £340 (330mm) Rears £320
Pads
Tested to the highest levels on the track with decelerations from 270kph (168mph) the HP2000 material is capable of operating in the most demanding conditions.
With excellent cold performance & bite, high resistance to fade, frictional stability throughout all operating conditions, reduced pad & disc wear and low dust levels, the all new HP2000 friction material offers significant advantages over its rivals.
Designed to be a direct replacement for the Original Equipment (OE) pads the Brembo sport pad comes with the exact same specification as the OE pad including (where applicable): fitted wear leads, slots for separate wear leads and anti-rattle clips with the added benefit of anti-noise shims on every pad.
Combine all of this with competitive pricing and UNECE R90 approval across the full range (making them street legal) and you get a true high performance brake pad fit for the road.
Evo 4-9 Front £135
Evo X Front £135
Rears all models £89
Evo X Front £135
***10% off the first 5 orders***
