boost problems?
stevo-with-the-evo
stevo-with-the-evo
Aberdeenshire
just got around to fitting my boost gauge today and it works great well at least i think so. took car out for a spin and it was peaking at between 13-15psi but then after changing in 3rd boost went up to 25psi and car kicked back at me? any ideas would be great?
stevo-with-the-evo
stevo-with-the-evo
Aberdeenshire
the hose that goes to inlet manifold not the one that goes to fuel regulator but the one below it to the inlet manifold?
I would be interested in knowing where you took the feed from too.
Have you checked all of the vacuum pipes to make sure that they are secure???
stevo-with-the-evo
stevo-with-the-evo
Aberdeenshire
i checked all pipes after i came back and the were fine. i'll get a pic up in 5 mins.
Agreed!
Bung that Tee off and start again buddy.
What make is the Gauge and is it mechanical or electronic???
The wires can come later.
Leave it until the morning and then make the changes in the day light.
I will get back to you on this around 11am or so to see how you got on.
stevo-with-the-evo
stevo-with-the-evo
Aberdeenshire
my tee is not on the one coming from fuel pressure regulator but the one below it goin into inlet manifold
Well swap them around as I have said then buddy!!!!
Once connected to the fuel pressure regulator, all of your problems will be history!!!
