Boost controller and what boost pressure...
B
Blitz668
Hi as per title, although I'm pointing towards a manual 3 port type controller, would that be ok? Or would electronic be best?
Also, what is the safe high boost to run, stock ecu, decat 3 inch, blitz induction.
I heard stock is 0.8 bar around 11-12psi... Would going to the 1.2 bar range be safe?
Remapping around March, just want a little bit more ummphh!
Many thanks in advance, noob here on evos.. Had s15 before and tuning routes maybe different...
Cheers.
Reece.
Reece.
I run a few more bits than you but still stage 1 but set at 1.6/1.7 bar and that is fine!
B
Blitz668
Oh I see. But are you running an upgraded fuel pump with that type of boost?
B
Blitz668
Yeh need to upgrade to that.. I heard its a mission to change? Drop the tank and everything?
Reece.
Reece.
As far as I'm aware you only need to lift the rear bench up and undo the inspection plate!
B
Blitz668
Yh thats what I thought! Subaru was the same undo the inspection covers and the top of the tank has s big cap on it! I think I maybe reading the wrong info and scaring myself!
with and use a 3 port boost solenoid to replace the stock 2 port
