Settings are always different from car to car despite similar mods.
You need to learn to set it up correctly. And don't run more than 1.3bar boost. You should also have the fueling checked if you intend to run more than 1bar ...
You'd be better of selling the avcr. Buying a 5/6 ecu, matching 560 injectors and a 3 port. Then getting it all mapped correctly and safely
