anyone got one of these in there car please help
evo arm's m7960
evo arm's m7960
can you not just disconect it and revert back to standard . the ecu is under the glove box and any cut wires should be easy to find and join back up :O)
if its any think like a billion vfc i had it just cut in to what was already on the car eg piggy backed on :O)
madmark
ok so here is a update turned the setting down as low as it will go 60 then said off so went up to 65 once it reached the temp the fans dident cut in temp carryed on climbing untill it hit 100 then the fans cut in says check white wire says on wireing diagram it goes to the engine computer ? were will i find the engine computer sorry to ask so many questions but i have no manual for the car
madmark
great will look tomorrow i fitted a amp to the car at the week end and tucked the amp wires up there so a bit of luck i moved the white wire cheers buddy
madmark
right update checked all wires and all seem good but fan still doesent work with the digital controller once it reaches the temp you set it at it just starts to flash and keep clinbing the evo also has a fet erg 050 super intelligent turbo timer fitted could it be anything to do with this unit it realy starting to do my head in now the only good thing is the fans still work with normal temp sender thank god so i can still use it but once it warms up over 70 on the digital readout it loses alot of turbo boost ? untill it cools down again then power is back untill it warms up again
