And so it begins
Wingnut247
Wingnut247
Block back and had its first coat of hammerite hammered finish blue! ImageUploadedByTapatalk1346186926.587786.jpg
Think B6lee likes it abit 2 much
raph
Just a heads up.. Loctite everything after you remove the balance shafts.
a mates Oilpump pulley came loose on his new cosworth block and made the belt skip... the vibrations from not having a balance shaft plus the stiffer mounts led to it.
Wingnut247
Wingnut247
Cheers matey! Will do!
Wingnut247
Wingnut247
Not much of an update for a while :shock: :)
Latest update!
All bits now arrived plus machine work done! Build date it this Friday! Pics of build will be added after!
drue1
drue1
nice one fella,getting there but its hard waiting for bits to come
martinthegooner
martinthegooner
looking good mate,glad you are getting it sorted,hope it didnt cost you too much.
Wingnut247
Wingnut247
Thanks mate! Will be doing a post on cost once it's all done! Recon it's going to cost about the same as buying a low millage standard motor with a warranty
Wingnut247
Wingnut247
The engine build! :)
Had a busy day yeasterday building the engine up, pretty well ready to refit to car now apart from a few little bits to bolt on! Big thx to Jamie at JB Racing for doing all my machine work for me, and helping me through the minefield of fitting Rods to offset pistons with very poor instructions!!!
B6lee is putting pics on as I am a techno failure and can't seem to do it myself :blush::blush: if only it was an engine I would know wat I was doing!
Will keep updating as engine goes back in! :)
Wingnut247
Wingnut247
Engine now fitted and incial start up done and duste! A few more bits and bobs to fit and rad to fill and it can come off the stands :)!
