jacko172
hey guys im a newbie as you know ive seen a very smart looking evo 4 however i need your lots advice if u think its a yay or a no ??
here is the spec list
The Lancer Evo IV, such as this is a rally derived car. Designed with the rallying arena in mind the earlier Evos are high performance cars built strong, powerful, fast and with four wheel drive to provide unrivalled handling and traction. It is this recipe that makes them such a devastatingly effective rally and road weapon.
The Evolution IV’s power comes from a 2 litre, 16 valve, DOHC turbocharged unit this is twined with a five speed transmission. The four wheel drive system incorporates active yaw control (AYC) this allows for increase control in high speed cornering by monitoring lateral g-forces, grip and power. The standard 0-60mph time for this car 4.4 seconds.
As can be seen from details below, on this Evolution IV many parts have been up rated to those from later models and also practical modifications have been made all to increase the cars handling, braking and performance.
The car always starts runs and drives very well. As with all Evo IV’s it is an import, all the changes made for it to pass the SVA test for use on UK roads were completed to a very high standard (such as the rear fog light addition). When the car was first purchased in Japan many Ralliart optional extras were chosen such as the dials, the gear knob and braided brake lines which just adds something to the car and sets it apart.
The car has all the usual Evolution IV GSR features and many others:
ENGINE
· 2.0 4G63 turbocharged 16 valve DOHC
· Forge actuator
· FSE power boost valve
· Walbro 255 fuel pump
· Magnex down pipe
· Full Ralliart exhaust system with decat
· Camskill blueflame CAT will be supplied
· XS Power Evo8 front intercooler
· Ralliart Intercooler water spray kit
· Intercooler hard pipe kit
· HKS mushroom filter
· Blitz dump valve
· Silcone Radiator hose kit
· Magnecor HT leads
· Aluminium spark plug cover
· Exedy Organic fast road clutch
· EVO 7 GSR exhaust manifold
· EVO 6 ECU
· EVO 8 Turbo
· 560cc Injectors
· Apexi AVC-R Electronic boost controller
· ECUTEK remap @ EngineTuner to 320bhp/275lbft with Dyno sheet.
CHASSIS & SUSPENSION
· Front Upper 3 point strut brace
· Front lower H brace
· Rear upper Cusco strut brace
· Whiteline rear anti roll bar and polybushes.
· BC Racing BR coilovers and pillowball adjustable top mounts
BRAKES
· Brembo Evo 8 front brake callipers, Ferrodo DS2500 pads with Black Diamond Discs.
· Ralliart braided brake hoses
· DOT 5.1 fluid
· Anti-lock braking
WHEELS & TYRES
· 7.5x17 Compomotive MO 1776 white 5 spokes.
· 4 matching Yokohama parada 2 tyres 215/40 17
BODYWORK
· Crystal side repeaters
· Gas bonnet struts
· Ralliart graphics
· Headlight and driving/fog light HID conversion.
· Genuine Mitsubishi wind deflectors
INTERIOR
· Recaro Bucket seats
· OMP 330mm alcantara steering wheel (Original comes with car too)
· KPH to MPH speedo conversion
· Ralliart Alloy pedals
· Ralliart dials
· Ralliart boost gauge (not fitted)
· Ralliart Gear knob
· Ralliart floor mats
· Sony CD player with USB
· FLi uprated front speakers
· Rear 6x9 speakers
· Sigma Thatcham CAT1 alarm and immobiliser with certificate and spare fob
· Power assisted steering
· Electric windows x4
· Remote central locking
· Climate control with air-con
· Tinted windows
The above performance modifications result in an impressive 320bhp whilst still keeping the reliability and functionality you would expect from this iconic Mitsubishi road rally car.
WORK CARRIED OUT IN THE LAST 6 MONTHS
· Timing belt and balance shaft belt
· Power steering, Air con and Alternator Belts
· Fuel filter
· Oil filer
· Engine oil with Miller CFS 10w60
· Gearbox, transfer box and rear diff oils – Millers premium gear oil 75W90
· Magecor 8.5 HT leads
· NGK double platinum Spark plugs
· Coolant
· Brake fluid change to DOT 5.1
· Tyres (As above)
· BC Racing coil over suspension
· HID conversion (Headlights)
· HID conversion (Driving/fog lights)
· 4wheel laser alignment and AYC service at K&R Mitsubushi
The car has been very well looked after by me and its previous owners, this is clear to see by not only the condition of the car but also the massive collection of receipts back to import date, a collection of MOT certificates and a book detailing the modifications and their cost. The car has been religiously serviced every 4000 miles and is always been run on Shell V-Power 98 octane fuel (this is advised but not required). The car will also come with an Evo IV English handbook (uncommon) and full workshop manual.
It does as with any car of this age it has a few small faults:
· The driver’s seat side bolster is worn from getting in and out of the car (a very common problem).
· A small scratch on the near side, side skirt.
· The heater occasionally clicks a few times when the car is first started or if heater control is changed to a certain setting- the local Mitusbishi dealer said this is a common fault and just the heater motor clicking in to position (does not affect heater operation).
· The folding mirror switch does not work (still adjusts mirror glass with no problem).
Due to the car being an import the digital part of the dash showing the odometer reading measures in KMH but the Speedo due to an interface reads in MPH. The car has covered 104,000kmph this equates to 64,600 miles.
The car is MOT’d until March 2012 and see no reason why it should not pass when this arrives.
The car is of extremely high spec having had many thousands of pounds spent on modifications that it will not disappoint, it is a real head turner and I have never known an Evo IV that sounds, looks or goes as good as this one does.
ENGINE
· Forge actuator
· Magnex down pipe
· Blitz dump valve
· Magnecor HT leads
· EVO 6 ECU
· EVO 8 Turbo
· 560cc Injectors
BRAKES
· DOT 5.1 fluid
· Anti-lock braking
WHEELS & TYRES
BODYWORK
· Gas bonnet struts
· Ralliart graphics
INTERIOR
· Ralliart dials
· Rear 6x9 speakers
· Tinted windows
· Fuel filter
· Oil filer
· Coolant
· Tyres (As above)
