Boost problem
yep definatly, get yourself to see alan. very highly comended in the evo world, you wont go wrong there for sure !!:):)
Ozy
Didn't know aftermarket dump valves could leak boost. Just thought the plastic ones would anyway got me thinking how could you tell if it's leaking anyway to check it.
they can if they are adjustable and not been set right :)
use a boost leak testing kit :)
W
Wellsy
Should that not be running a bit more with a 9 turbo ?
Try putting the dv back on if it drives fine then it's got to be your coil packs I'd still be sorting a new set though
