Dan_mansfield
in the higher gears as i get round to over 5k i experience boost cut.is this due to the cold weather causing it to over boost or should i check some bits out.only mods i have is decat system panal filter in the standard airbox and a fuel pump i kno these mods without a map can cause the boost to creep anyways.would you reccomend fitting a boost guage and seeing at what psi/bar i experience the boost cutting.cheers in advance
