Look what came today :)
Seen this for sale at the weekend and just had to have it :)
S90 70mm throttle body, mmm shiny :D
Will be removing the inlet manifold to get it ported to match and ill let you know the outcome :)
Very purty
Sent from my HTC Desire S using Tapatalk
GG205rob
GG205rob
I didn't realise geof can read. I thought thats why he posts so many pics. Lol.
Nice and shiny mate.
goes here mate :)
one would look nice on your car. could get your inlet manifold cromed to match it in with the rest of your pipework :)
goes here mate :)
thought about getting that chromed but what if small particals got into the pistons :shock::shock::shock::shock: may get it polished and then laqured up
did you think about that when you had your hardpipe cromed ? :)
uprate yours geof dont polish it. get one like lee's :whistling:
How much difference does it make performance- wise?:)
The S90-Racing Throttle Body is the Breathing Point of your engine. With a Larger Oversized Throttle Body, you can supply as much air as the Intake Manifold demands. Whether you have a set of Aftermarket Cams, Supercharger, Nitrous or Turbo, Oversize Throttle Bodies will deliver More Horsepower!
Oversize Throttle Bodies work well with Fuel and Air Upgrades.Use of a High Flow Air Intake is required, as the opening is larger than the Stock Intake Piping. Match Porting your Intake Manifold will help Maximize the Larger Throttle Body Diameter. S90-Racing Throttle Bodies are made from CNC Billet Aluminum AL6061 and are a direct replacement for the OEM Cast Throttle Body.
A Special Billet Throttle Blade & Shaft made from AL7075-T6 is included to increase Full Throttle Response and Acceleration, especially installed at Force Induction engine. AL7075 material can stand for highest boost pressure to 3 Bar we tested , Both side of the shaft was comprise of Branded Ball Bearing to put out the best respond.
You will need to reuse your stock Map Sensor and TPS. These can be reused from your stock throttle body.
Would make f-all difference on a stage 1 modified car, but Lee will see some differences due to his state of tune :) I just hope they haven't sent you a 7/8/9 one rather than a 4/5/6 one. I think they look great :)
Lee - whilst its off, if you haven't done it already, get some PTFE gaskets on!
its off an viii but spoke to Ant and he seems to think cos of the ecu i have that it will be fine with my tps fitted :)
yea i heard about these ptfe gaskets. might get meself one fot the inlet mani :)
