richyx
ok i have a weird problem which i carnt get my head round
the boost was increased when i had the car mapped and now the screamer pipe doesnt work
everything is fine with vac pipes and stuff but i carnt understand why the screamer pipe has stopped working, if i put the boost controller on a lower setting the screamer pipe is back, but it doesnt work on the boost setting i need it to be, als the boost controller is maxed out to give me only 1.5bar
its a 38mm wastegate so am i going to need a bigger spring to give me more boost now or at least lower the controller for future settings
from what ive read and seen the wastegate only opens to release excess pressure so on high boost setting its hitting its max setting but not to much to move the spring in the wastegate? but on the other settings its overboosting to give me the desired boost setting for low boost hence screamer is working or have i got that wrong
if i havnt then for my screamer to work i need my turbo to be over boosting?
its annoying the hell out of me as its the noise from the screamer which i love and now without it the car just sounds bland
