- Moray, 57N
I'd be tempted to re-wire the entire dash and forward section with an original loom.
I'm gonna be honest.... What the hell was you doing buying a car that doesn't go ?!?! :shock::shock: Lol did you test drive it at all ?
The ECU is either a black or silver box with shed loads of wires coming out of it, it should have like a name on it depends what ECU it is, I.E Mitisibushi, apexi, etc etc.
And should be around the passengers side foot well, or behind glovebox round that area.
That pipe off the solenoid, could be a boost pipe came off, but need pics or video to see really.
Where abouts are you? What part of the country you from? Cos maybe a member or trader on here could help you abit more.![]()
explanation of fix for running issue then pls![]()
I would check the upper arm mount myself for any damage as these were a recall job by mitsi
You'll find that the mounting point that is recessed into the car brakes at the join point from the manufactureing process
Why the Recall work should be done... - Mitsubishi Lancer Register Forum
Link is my thread from over the road
thers 2 bolts on either side one adjusts toe (top one] other camber, your more than likely that when you go to adjust them at least one will strip it threads, there not that cheap either but i found ears motorsport stock them and usually deliver next day.........
cheers that is very helpful... Another question whilst on suspension, are evo 4's a hard ride on ********standard shocks and springs*********??? when driving i feel every little bang in the road, not like the impreza very smooth not as aggressive in the suspension
depends what type of set up you have, have you got coil overs?
