Plx helP
alan_choi2000
alan_choi2000
I had a MOT. Fail in emission. The people said co Level too far high.
It is 7 now, it suppose to be 0.5 pent. Does it mean the cat gone?
alan_choi2000
alan_choi2000
Yup got a cat . Manufacturer one.
They just dun know what wrong.
What happened is, this year i upgraded the fuel injectors 560cc n put the whole bottle of fuel injestor cleaner in just 20 pounds fuel. Just before MOT
Last yrs I put unknown ecu e5. The MOT was fine.
Is there anyway to test?
alan_choi2000
alan_choi2000
Plus one person suppose, bcos I put bigger injectors, the amount of fuel put in, make the the engine work harder. Or the excess fuel without burn , may damage my cat ??
I v. Pussy off. He suggest me to put the old injestors back .
alan_choi2000
alan_choi2000
I'm thinking is it bcos I hasn't remapped it proper. So make engine works harder.
Plxplzplxplx help
My last day for retest is on firday
Your english is terrible.
Did you take it for a blast before the MOT? You need to get the catalytic converter hot for it to work efficiently.
GG205rob
GG205rob
If its on a 4 it shouldnt even need the cat. Its not eu type approved so should be non cat tested. That means the limits are nowhere near as strict. I think 3.5 percent. Still not enough to get yours through but easier at least.
alan_choi2000
alan_choi2000
I think so my English is not that good.
I drove it to MOT center. It should be hot. I dun know wot to do.
alan_choi2000
alan_choi2000
Really ? I dun know. What else I can do?
GG205rob
GG205rob
I know its tru for the 4. Not sure about the 5. It all depends if its type approved. If not the dvla dont keep any emissions data for them so tested as non cat.
GG205rob
GG205rob
I know quite a few mot testers. Got one of them to check the vosa guidelines and thats what they came back with.
stevo-with-the-evo
stevo-with-the-evo
Well I'll be puttin it through decat next year see wot happens
GG205rob
GG205rob
Just question it if it fails, if they look it up then they should pass it. (obviously assuming the emmisions arent stupid high, but if theyre that bad youve got problems)
5 ecu and injectors should work together fine. That is unless maybe the ecu has been re mapped by previous owner.
stevo-with-the-evo
stevo-with-the-evo
The car has been mapped so maybe it would fail then?.
