is this a known fault
C
cherryredbenj11
The drivers window on my 6 is dodgy. Sometimes when the window comes up it stops and goes back down again. It seems to me like its partly come off the rails and is out of line. Is this a known problem? cheers
No. Has this done this since ownership? It sounds like something maybe broken inside the mechanism causing it to get stuck as it rises.
Pull the rubber runners out and give a clean mate. Sometimes dirt gets stuck in em and stops the window goin up
C
cherryredbenj11
ive only owned the car for a month. It seems as if one side of the window goes further up than the other side when it rises causing the glass to come out of the frame
If its not goin up properly and straight check the runners I had to replace them on my last car.
