evo arm's m7960
hi guys ,
im not saying you should use this but just take a look :O)
i recently fitting a new intercooler to my e4 that worked out to be to big " i didn't think you could go to big , my mistake dou !!
so after some searching i came across this calculation for working out your inter cooler size . taken from a total vauxhall mag ,
the idea is to stay close to this number if you can , go a lot smaller and loose power and thermal efficiency go a lot bigger and loose power and turbo efficiency . so if you car only makes 400bhp dont try and fit a 600bhp cooler dou !!
as a rule of thumb you will need
3-litres of volume per 100 bhp = 3L
a cross section of 50cm squared per 100bhp .. hight x depth = 50cm2
eg
as a rough guide
for 300 bhp you would be looking for a 9 L cooler with a cross section of 150cm2 .......... 3 x 3L and 3 x 50 cm2
for 400 bhp you woulds be looking for a 12 L cooler with a cross section of 200cm......... 4 x 3L and 4 x 50cm2
for 300 bhp , if say you where looking to get a cooler with a 2.5" core " 63.5 mm" to get the 150cm2 cross section you would be looking at a cooler with a height of around 24cm h x 6.35cm or 240mm x 63.5 mm = 152.4 cm2 "close enough" .
you will also be looking at a length of 9L devided by 152.4 to get your volume = 9000/152.4= 59 cm giving us a cooler of
240mm h 590mm w 63.5mm d for our 300bhp i would treat this as a minimum size needed
as a idea my big cooler works out to be
300mm h 600mm w 100mm deep 18 L 300 CM2 cross section good for 600+ bhp dou !!
making it 90% bigger in size and volume than my old cooler
so to finish for my 420 bhp i have chosen a new cooler
300mm h 600mm w 76.2 mm d . 3 inch core
420 bhp x 3L per 100bhp = 420 x 3 = 12.6L needed
cross section of
420 bhp x 50 cm2 per 100bhp = 210 cm2 needed 4.2x50 =
the new cooler works out to have a
228cm2 cross section 300hx76.2w =
13.68L volume = 600w x 228cm2 =
making the new cooler good for around 456 bhp ..
remember this is just the cooler not the pipe work :O)
this is just a guide that i wish i found earlier but i dont really do maths so forgive me if i got somthing wrong , as i stated i took the oe sum from another sorce thanks t vaux mag :O)
eg
as a rough guide
cross section of
