what ecu's can you put on this car... can you put one off the later cars
regards tom![]()
Check out the link I posted back on page 1, post 3 :sneaky:
Should help with the basics to start you off .... :twisted:
regards tom![]()
yes to the ecu but dont forget to change the injectors for the 5 or 6 ones . there bigger
and its a intercooler spray button :O)
wheres the bottle to fill it up
regards tom
works off the same bottle as the windsceen washers use
right, i have got the new gear linkages I was after... I have took the old ones out and put the new ones in!!!
Now the problem I have is the cable that controls the left to right movement of the gear stick seems too long on both the new and old cable.... It is like the lever arm on the box is bent or something... I don't get what is wrong??
Maybe some one has had similar problems it looks like it could be something so simple but because I haven't got any pics of a working set of linkages in location I have nothing to compare to..
Thanks again guys any help appreciated
try and pop a picture up mate
:O)
Check the pipe on top of the transfer box mine cracked when I pulled the engine out and leaked like mad until I repaired it
yes a little o ring between the gearbox and transfer box....
Its located between the boxes. Transfer box off job which involves removing the wheels, disconnecting drive shafts, suspension, using a slide hammer to pull out the output shaft and dropping the transfer box. Gearbox remains in place. Best to replace all 3 seals while you are in there, only £5 for all 3 from camskill.com
When mine leaked it was the big O-ring, not the small one, so order all 3 so you don't drop it to find you don't have the right one.
Can't check just now mate, I'm in Italy and back late tomorrow night. If no-one has posted the info you need by then I'll post links to the seals you need.
