Bimbo..
A
AndyK
Sorry, I mean Brembo!
Ok, folks, I have a 4, what do I need to do to convert to the Brembo set up as I am going home to Russia in the next month or so and parts are cheap, cheap, cheap over there? any comments appreciated!
brembos and mounts and change of wheels to fit with new discs
lolz none of us do........... lol
as far as im aware you will need bigger wheels to fit the calipers in and obviously bigger discs to fit the brakes
EVOIV MJC
EVOIV MJC
Brembo calipers
Braided hoses
Caliper bolts
Bigger disks to suit
Wheels to fit over the said calipers
Looking at the pictures of his car he has e6 wheels, that'll be fine.
what sort of monies are you looking at to get your brembos? how much cheaper are they over there?
saving dosh is always good lol
A
AndyK
Hi mate, well, my brother in law is in the car business and he has lots of mates that give him bits dead cheap, but are the Brembo calipers of the later Evo's all the same as the earlier ones? as I have only seen later Evos there?
Later ones are bigger so I think you will need the mounting bracket for the caliper
Only the 10's have larger brembo's, 5-9's have them same calliper and brake sizes.
No bracket required. Brembos from Evo 5-9 will bolt straight on using the brembo bolts.
You'll also require the discs and pads from an Evo 5-9 also :)
A
AndyK
Just thought..the weight of those buggers will probably cost me more in excess baggage weight charges! :meh:
There will be loads of people selling them on the MLR if you're after a set.
