Got It!
A
AndyK
Hi all,
Finally got the car delivered yesterday, looks good, needs ALOT of TLC, LOADS INFACT!!
Drove it half mile down the road.....stopped!.. :meh:
AA called out... fuel pump dead!!!...:blush:
Now, I see this as an opportunity to whack in an uprated jobbie?? how easy is it to change the fuel pump folks?
yes
remove back bench
remove inspection cover behind drivers seat
disconnect pipes
unbolt cover and lift out
replace pump
refit in opposite order
done :)
evo arm's m7960
evo arm's m7960
hi buddy well done on getting your new car .
sorry to here its already broken down :O)
ive also read that a faulty crank sensor will also give the symptons as a dead fuel pump , respect to the aa and all that :O)
good luck mate
evo arm's m7960
evo arm's m7960
yes
remove back bench
disconnect pipes
replace pump
done :)
hi rsvrob good advise :O)
wont he have to cut the metal fuel pipes under the rear seat on a evo 4 and join them back up with rubber hoses ??
:O)
:O)
yes
I did on my 4
cut on edge of inner lid to lift out
when you refit just join with very short piece of fuel line
A
AndyK
Hi guys,
Thanx for the advice, much appreciated! looks like someone has already changed pump as the lines are now rubber jobbies?
Popped to Halfrauds yesterday and got meself a nice tool kit, (50% off folks!) guessing I will need it now I have an Evo! :whistling:
All i need now is an expert to come over and diagnose the strange diff problems?? It's on it's second diff?? :confused:
gooner8
gooner8
hmm evo 4's normally don't have prob with the ayc like the newer evo's do.not saying there bullet proof! So is your ayc light on? Or is there noise or a clucking sound from the diff or rear end? :)
A
AndyK
Hi mate,
AYC light off, but when the AA bloke took her off his truck he noticed a noise and the wheels didnt seem to want to free wheel when it was rolling??
I am waiting for a fuel pump as it died the day I had it.. :eek:
gooner8
gooner8
ok buddy let us no when she's running again.would of thought the ayc light would come on if the diff was playing up? Just so you no my ayc light came on when i had a flat tyre! 5hit my self till i notice it was just a flat tyre! So it mite not be your diff is the point im getting at lol maybe some thing else. :)
A
AndyK
Cheers bud, ill get back to you when i bring it back to life :whistling:
