Evo4 with evo8 engine has very strange engine work
robotech
engine is from evo8 - working very unstable - seen on the video.
I though at first that are forking only 3 of 4 cylinders but are working all. acceleration is ok - unstable work is only when standing on idle. when driving - goes ok.
what could be the possible problem? MAF? o2 sensor? could be some kind of idle valve (if evo has one)? or could be some serious problem?
I know that diagnostics could tell the problem but i need to know at least guesses for now.
video:
[ame=http://www.youtube.com/watch?v=_XdiknAQXxI]video-2011-08-24-11-22-54.mp4 - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=jLYo7M8e-dc]video-2011-08-24-11-33-34.mp4 - YouTube[/ame]
Thank you!
nice first post fella, we are after all a problem solving forum hence the reason why you have to sign up just to ask a question
sounds like tappets need replacing.
what do you mean by unstable? are the revs going up and down, couldnt tell from the video
pop along to the newbie section mate
robotech
sorry for that
tappers those are those on valves?
problem in only when idle. on the move seems fine
by unstable i mean that engine seems to want to turn off when idle
check the position on the idle screw or spark plugs
How long has the 8 engine been in the car?
Have you changed anything and the problem has occured?
Does it idle very low on rpm?
Does it try to stall when you lift of the accelerator?
Does the idle hunt and not stay stable?
Has the battery been disconnected for any reason?
Many questions I know but answers will help narrow the search :)
robotech
has no idea how long. i am buying
no. idle rpm are ok. sbout 900
yes. tries to stall when leave accelerator
yes. idle very unstable
possible that battery was disconnected
robotech
btw ayc lamp is on. check engine lamp is off
If you buying then check the engine number to confirm it is an 8 engine
You say it idles at 900 then tell me it hunts, which is it?
Battery disconnection normally meens idle needs resetting
If idle tries to die when you drop of accelerator it may be because you have a vent to atmosphere dump valve causing the issue
AYC lamp on means new pump or pressure switch = lots of ££££
Mid Wales
start with the simple stuff,
is there much black smoke when driving on boost?
check all pipework for air leaks, spraying wd40 around all associated parts can be handy to spot leaks.
robotech
haven't noticed much smoke. and on idle when press gas pedal and release - no smoke.
btw i've noticed a bit of a smoke coming from one of the pipe. very very little but still.
robotech
no, i don't have proof that engine is from 8th. current owner says that.
could 8th engine cause some trouble in 4th model in future?
it idles on about 900 when you press gas and release it - it's trying to switch off the engine. and one time i saw it switched off the engine
AYC pump and pressure switch are that muchs expensive?
does it mean that it's better to change the whole ayc if i get it?
the thing i need to decide is that - do i need to buy that car or no. exactly 4th model i like most of all and they are not sold in my country. the current one is the only one for sale in my country.
so actually those two issues i am very concerned about.
Having a later 8 engine will not cause problems but will hold a higher price than the std 4 engine
Ayc problems will lower the asking price as it means something needs fixing ... lol
Mid Wales
sort any leaks first no matter how small as they can cause it to hunt on idle.
robotech
Welcome Robotech!
Would I be right in assuming you are from latvia?
yes, you are right - I am from Riga, Latvia.
and we have LHD traffic and if i buy it i'll have to convert it to LHD
Matt-evo-v
Matt-evo-v
Aberdeenshire
Robotech.
So you can confirm the engine is an evo 8 engine:
EVO VIII 260: HY (USA),JX, KL, KO, KQ
EVO VIII: HM, HP, HQ, HR, HT, JC, JD, KS
EVO VIII MR: JY, KA, KB, KD, KH, KJ, KK
The engine code should start with one of these pairs of letters.
Sorry, I can't help with any of the other faults. Although, I would be very cautious about buying one with the AYC lamp on, as it has already been said, that can be an expensive fault to fix :(
robotech
Robotech.
i see AYCs at ebay starting at 200gbp or i am missing something? pump is outside the dif, right?
there is no question to buying one with AYC on or other - there is only one for sale here. i thought also to buy one in the UK and bring to my home.
Matt-evo-v
Matt-evo-v
Aberdeenshire
Hi Robotech,
I really don't know how much these AYC pumps sell for. I guess £200 may be fair, but I would have thought they would cost a little more.
Speak with John@evobreakers on here, he may have some forsale and he is a decent guy.
Would it be more expensive to buy here and take it back?
robotech
Hi Robotech,
i've bought evo4 that i was talking here about.
ayc lamp is on. found one from evo6 in my country for 240gbp with ayc ecu. but pump is outside the ayc?
on Monday will show car to guys that do evos repairs.
engine run's fantastic except that problem on the idle. some people said that it could be due to hks camshafts that i was told are there.
