wheel alignment setting
doylerevo
doylerevo
hi guy and girls
im looking for alignment setting for my evo 7 which has 18" alloys on it,
so think setting should b different to standard 17"... :thinking::thinking: my steering is out the window at the min:mad:
any help i would be greatful
Marty.H
Stock wheel size settings are
Front camber: 2 degrees -ve
Front toe: 0 degrees 8 minutes total toe out. 0 degrees 4 minutes per wheel toe out.
Front castor: Whatever the stock, non adjustable set up can give me.
Rear camber: 1 degree -ve
Rear toe: 0.00 degrees total or parallel.
doylerevo
doylerevo
Thanks
so should this be the same for 18" as well.
Marty.H
Cant see 1" making much difference even though some say it will
evoaps
evoaps
would it not also depend on the tyre wall height as 18s with low profile tyres could be smaller diameter than 17s with normal tyres?
doylerevo
doylerevo
I'm runnin 235/40/18 and stock is 235/45/17 . . So will stock settin
g b ok
i'd say it depends on what you want to use the car for, if its mainly road then you could do
camber toe
front 1.5 0
rear 1 1
track
camber toe
front 2 1
rear 1.5 1
W
Will Seng
camber toe
front 1.5 0
rear 1 1
track
camber toe
front 2 1
rear 1.5 1
Hi sir, may i know the caster needed to be adjust? Road use most of the time.
