Gt4 boost
evoaps
evoaps
I ve recently bought a Toyota celica gt4
Want to turn up the boost as it is running standard pressure to about 1 bar
Wats the cheapest way to do this?
BenV
BenV
if i remeber rightly they are restricted in first a nd second to a lower boost level but im sure if you put a boost controller with the new solenoid and new vac lines to suit that should get you to a decent level
Marty.H
Cheapest way would be a Daws device other then that and electronic controller will be needed
evoaps
evoaps
I heard that too that a bit stupid??
Thanks guys
are you planning on doing anything to the ECU? to make sure your fueling is ok? I've mapped a gt4 with a emanage ultimate in it and got some good results
