They see a comfortable 450/450 ish you can push them a bit harder but to be honest 450 bhp and the same in torque in a road car is more then enough.
I have been looking about for cheap V or VI engine that needs a rebuild can have a good poke about with the evo engine then and may even put an engine together for my IV
another engine i like to play around with old school this one
Thats the engine i use to run in my lightning rod
Spec of that was
Head work been done is :
130 thou removed from face
New cam bearings
Kent GTS2 cam
New rockers
All new valve seats
New valve guids
All valves machined into seats at same depth so when setting clearances all rockers even
3 angled valve seats
New valve stem oil seals
New kent cams vernier
New K&N filter
Carb:
32/36 DGAV
Re jetted
Larger Venturi's
Choke's removed
Power valve blocked
Bottom end 205 Block:
10 thou decked
Mahle pstons
STD crank not been ground
Has been stripped and checked all new gaskets fitted
New water pump
New Cambelt
Dizzy been done NO vac advance
New Coil / dizzy cap / Rotor Arm
As you can see i like to play around lol
