What plugs?
chillipepper
chillipepper
My plugs are due to be changed on my IV around now, i have HKS irridium at the mo but a bit short on cash so whats the next best thing and where to get them?
Also wot gap should they be set up at??
Thanks
Ngk bpr8ex cheap but good :)
Can't remember the gaps lol
RSmark
RSmark
If you cant afford a new set. I'd personally clean the plugs with a wire brush etc. Then stick them back in for a couple of weeks until you have the funds. I only use the same plugs as you've mentioned.
The bpr8ex plugs are only around £10 from a local motor factors
RSmark
RSmark
They the ones in a light brown package? If so they aint too bad, thought they were around £20?
Jones the boost
Jones the boost
Have alook here.....
http://www.*******************/showthread.php?t=356456
My local motor suppliers sells me NGK BPR8ES (copper) for £1.25 a plug and BR8EIX for £6 a plug and gap them to 0.7mm which is pretty much what they come out of the box as.
If it starts missing under boost then just drop the gap down a wee bit although I dont have any issues running 1.85bar
