youngy_315
firstly, does anyone know if evo x alloys fit on a 5 without any issues?
and secondly, what gauges do you recommend other than boost? :hm:
its your lucky day, without looking i just came across these![]()
anthisite rules !!
whats this about alarms on defi's ?
Not sure but aren't the x wheels 18" !!
I believe the TME wheels are the same with 12spokes only 17"
You can set a max value for the gauge to read before it triggers an annoying alarm at you. I set it for more than 120 degrees oil temp and 2.2 bar boost. The oil pressure I've gone the other way round, it sounds if it goes below 1 bar.
Yes X wheels are 18" and they are slightly different design to tommi wheels![]()
So is that what the controller is used for then ??
if i were to get a fuel pump and remap, would it be best to run with an apexi avcr or would another electronic boost controller suffice? at the moment i will not be looking for more power on top of that.
