RSmark
Is the altenator on the rear of the engine?
I have found the ticking noise to come from there, once sprayed with WD40 on the cambelt on the i assume altenator bearing which the cambelt is on the ticking stops.
Will a worn bearing or bush cause a ticking noise?
