compression test
B
bhp-mad
hi all, iv got a evo5 done 70.000miles what would be a good pressure to have or can someone tell me the compression in the pistons when they were new???thanks
HermaN
HermaN
When fully warmed up on WOT it should be...
Minimum - 9.7 bar (140psi)
Standard Value - 11.5 bar (167 psi)
Limit between cylinders - 1.0 bar (14.5 psi)
jamie@evotune
Normal comp pressure you will see on a Evo engine is 120 psi across the cylinders.
Anything bellow 100 psi and I would be investigating it further I would also carry out a cylinder leakage test as a comp test will not always show a fault on the engine.
HermaN
HermaN
120psi?! When warmed up with the throttle wide open?? None of the engines I have tested have been that low. The last 8MR I checked was 175, 170, 180, 175
The figures I posted above are also directly from the service manual. 120psi is too low on a fully warmed up engine on WOT.
B
bhp-mad
test done
hi thanks for the replys...i was getting 150 psi on all pistons with the throttle closed on 6 turns of the engine is this good or not .
jamie@evotune
Well all the ones we see are around that figure I know what Mitsi say but it is very rare that you will get a Evo engine that has above 155 psi per cyl.
HermaN
HermaN
.....but it is very rare that you will get a Evo engine that has above 155 psi per cyl.
I always do a compression test as part of my pre-mapping checks and not had any below 140psi yet, all are 150+....:confused:
@ op, 150 per cylinder with throttle closed seems good, but the test should be done with the engine @ operating temperature with the throttle wide open.
B
bhp-mad
the engine was at operating temp , but i will do it again with the throttle wide open ...how many times do i need to turn the engine over ????thanks
