Standard boost psi??
dannylancer
dannylancer
Hartlepool
So I spent today cleaning the car and had the idea that removing the back seats and trims would save me a bit of weight until I got them out and realised they actually weigh less than my puppy lol, anyway I fitted a boost gauge while I was on just to keep an eye on things and it's seems I'm boosting at 17/18 psi, is that normal for a 260? Small mods like k&n and cat back exhaust nothing major.
HermaN
HermaN
Aberdeenshire
14.5psi (1.0 bar) is standard. However, with induction kit and exhuast, 17/18psi (1.2 bar) is norm. Note that on a cold day you might hit boost cut (about 1.3 bar),to get round boost cut you need a remap.
Breathing mods will cause boost creep like you have found.
dannylancer
dannylancer
Hartlepool
Ok thanks for the input mate, is this still safe tho or will it cause me a problem?
HermaN
HermaN
Aberdeenshire
Always a good idea to get the fueling checked. Any place with a dyno will do a power run and check fueling for approx £50. Or if someone on here is local to you they might be able to check for you on a wideband.
Bristol
get yourself a wideband then you'll always be able to monitor the AFR, normally cars are a little rich when straight from the factory so your probably on the limit now, as said would be worth getting it checked over by someone local
dannylancer
dannylancer
Hartlepool
Well I'm getting a remap next month so could it cause me a problem between now and then?
dannylancer
dannylancer
Hartlepool
Ok Jamie nice one, just don't wanna melt anymore pistons or anything like I did with the scooby lol
