need a tiny bit of help
mark
mark
GRIMSBY
this is the second time i have wrote this out, the first time it didnt post and it took 20mins to write :confused: gutted
right here we go again
i fit my hks rs induction kit today and i was a pipe short as the pipe from my standard air filter box didnt fit, i also want to fit me dump valve but i think i need a t piece (is this correct) ive took some pictures ill try put them on but not promising lol this may take a while :confused::whistling::whistling::whistling:
cossie
cossie
beds
Get the pics up mate I don't think you need a t piece but think you will need a bung for one of the pipes
Hereford
Get the pics up mate I don't think you need a t piece but think you will need a bung for one of the pipes. tell you wot ill give you one of my butt plugs ive got lodas of them. yes you have guessed im a
:disgusted::disgusted::disgusted::disgusted:
mark
mark
GRIMSBY
tried getting pictures up they start to up load then a problem occurs
anyway the pipe needs to go from the hks there is a piece sticking out of it for a pipe to go on its about 1 inch in diameter and it goes towards the back of the engine connecting to another bigger pipe
hope this helps
hope this helps
That is the pipe that you need to connect your dump valve to buddy.
Why do you need a T Piece buddy???
What you need to do is utilise your existing hose which the Recirculating Dump Valve was connected to.
The other option would be to use a blocker and bung it up (this would also be the case if you decided that you want to fit an Atmospheric Dump Valve).
Using a blocker on one or both ends will depend on which Dump Valve you have or on if you decide to you don't really want one.
PM me your email address and I will send you a pic over tomorrow at around lunch time of what the end result should look like so you know exactly what to do! ;)
mark
mark
GRIMSBY
nice one el
email address removed, use PM to stay safe :) Nick
mark
mark
GRIMSBY
right try this
mark
mark
GRIMSBY
yippeeee picture is up shiney pipe on left and mucky black rubber pipe lower right do i need a pipe to go across there :confused::confused::confused:
mark
mark
GRIMSBY
some more pics :whistling::whistling:
Needs blanking of if your runing a VTA bov or pipe attaching to a recirc valve
mark
mark
GRIMSBY
not sure wat it is so ill put a picture up now am getting the nack of it lol 2 mins
Forge or r-spec copy...
VTA bov mate. You get the pssshhhh noise on lift off?
Block the hole on the new hard pipe mate. Bit of 35mm hose and a plug. The bov attaches to the upper hard pipe. All sorted then...
RSmark
RSmark
Swindon
that DV need to go into the rear pipe, hard bit i can see in the 1st pic. then the small vaccum hose fits on the top of the DV. Then you need a blanking plug to fit where the stand Valve used to be.
Possibly need an overall shot of the engine bay.... just to confirm what pipe is where
