K
krusty
got the program working to read the data out and did 2 logs
1 stationary
1 driving down the road
question is how do i read the log files? open in notepad/word and its data thats not in line with columns
any way of contacting clanzer (no recent postings on his site) or andyf ? (gmail addresses are banned from his site and made a request 4 days ago with no answer?
i need to look at the data to see whats happening cos after a thrash it cuts out (over/under fueling?) when you come to a stop, but re-starts and idles ok after.
1998 rvr hyper-gear x3
td05 turbo fitted
BIg front mount ic
mushroom air filter
3 1/2 inch straight pipe s/s
evo 4 exhaust manifold
running 560 injectors (was 410's)
its a standard ecu at the mo but the questions are
1, am i going to kill it if i dont get it mapped?
2, is there less chance of killing it if we just stick the 560's in?
3, what is the ecu the same as?
4, what is the proceedure for flaashing to the ecu? i have various cables from the past any suggestions? what will work? the one that reads ok is some crappy thing i got off the bay a fews years back (wouldnt work with anything back then)
kwp2000
galletto 1260
gendan (vauxhall based, but still iso9141)
universal obd reader (can edit vendor etc to trick s/w)
rs232 based op-com cable runs com not usb (can usb it via my dakota serial hub)
is it pure obd to read log flash? or do i need connections from white socket next to the obd plug?
OR do i use eprom programmer on ic thats been removed?
thanks in advance
1 stationary
td05 turbo fitted
BIg front mount ic
mushroom air filter
kwp2000
galletto 1260
thanks in advance
