What Oil's....
chrishfq300
chrishfq300
....are people using.
Always used Mobil1 in previous cars but have only used Shell Hellix in the evo... wondered what everyone else uses or recommends...
Nothing but silkolene race for me 10/50
It's now called Fuchs Titan same stuff different name
I know that's what lots of people use in the Evo world :)
Steveyb_evo3
Steveyb_evo3
I can get u some Awsome oil mate at near enough the sime price as opie oils do that silkolene crap I have seen them test them side by side and the difference is amazing
I used to use silkolene in everything now I won't go near it
Why ???
Steveyb_evo3
Steveyb_evo3
Just after seeing this other oil they run a test where they run a bearing dry and 1 with wot ever oil u take with u for a set amount of time with diff amounts of pressure through the test and after identical tests the silkolene had warn nearly half as much as a dry bearing but the same test on the oil I now use and the wry team are using that was reduced by half again
Steveyb_evo3
Steveyb_evo3
Don't get me wrong there is nothing wrong with silkolene I used it for years but after seeing that there is no way I would go back
chrishfq300
chrishfq300
this the same oil you keep using with all these bottom ends...? :whistling:
Steveyb_evo3
Steveyb_evo3
Lol nah not used it in this car yet only on my old ones I used the oil they recommended so as they have no comebacks while under warranty
kennye68
kennye68
Personally I use millers 10w/60 ! A bit expensive but you can't beat quality also use millers one shot octane boost before every fill up,gives you an extra 3 octane numbers ,vpower is 99 octane so this boosts it up to 102 ,also improves emissions,cleans injectors and ups the bhp slightly {only about 6 quid a bottle}
