The flagsquad chat thread
chrishfq300
chrishfq300
its ok si we will pop over to geekmapping and start our own thread :whistling::whistling::whistling::whistling: im on there too ;):p:p:p
hahah.. funny you mention it Geof but im also a member there! :twisted::twisted:
chrishfq300
chrishfq300
Hexadecimal (also base 16, or hex) is a positional numeral system with a radix, or base, of 16. It uses sixteen distinct symbols, most often the symbols 0–9 to represent values zero to nine, and A, B, C, D, E, F (or alternatively a–f) to represent values ten to fifteen. For example, the hexadecimal number 2AF3 is equal, in decimal, to (2 × 163) + (10 × 162) + (15 × 161) + (3 × 160) , or 10,995.
Each hexadecimal digit represents four binary digits (bits) (also called a "nibble"), and the primary use of hexadecimal notation is as a human-friendly representation of binary coded values in computing and digital electronics. For example, byte values can range from 0 to 255 (decimal) but may be more conveniently represented as two hexadecimal digits in the range 00 through FF. Hexadecimal is also commonly used to represent computer memory addresses.
haha google is your butty;)
bit pssed of today anyway geoff, engines gotta come out, work work work cash cash cash
wots up with it?? i did see ya thread about something but thats all over my head i can only put petrol in and that woz 3 times last year :whistling::whistling:
piston clearances and headgasket problems, its a complete strip down and build, well pssed off
