Missfire
markd77
Rotherham, S Yorks
Wonder if anyone has any idea about this one.
I was suffering a slight intermittent missfire on my Evo 8 FQ340 so changed coil packs, plugs and leads.
Car still ran like a dog.
Gradually got worse to the point where when I started it revs would dive up to about 2000 then drop to less than 500 and car would stall.
If I unplug one of the ignition leads, run the car for a few seconds on 3 cylinders, then plug the lead back in, the car runs perfect.
I'm getting no fault codes when I try to pull them.
Totally confused with this one.
Any ideas?
markd77
Rotherham, S Yorks
Yep, I've put 2 new sets of leads on it.
Would the idle control valve cause a miss while it was running, not just on idle?
stevolution2010
stevolution2010
oldbury(WEST MIDLANDS)
not sure have you tried re-setting ecu i think u have to leave the battery off for 24hours then it re-sets everything
may be crank sensor?
wheres lee he mite have a better idea:blush:
I would have said plugs, leads or coil pack but if you have changed it already then I'm unsure.
Did you gap the plugs before you fitted them ??
markd77
Rotherham, S Yorks
I had them fitted at a garage so I've no idea :confused:
If the plugs weren't gapped correctly wouldn't it run like a dog all the time? This fault is intermittent.
Cheers.
stevolution2010
stevolution2010
Cheers.
yes mate my plugs were gapped incorrectly and mine was missfiring on the rollers id check what plugs were put in it aswell
markd77
Rotherham, S Yorks
Okay thanks will give it a go. What should they be gapped to?
Also, I've heard they need to be torqued when refitted, is this right?
stevolution2010
stevolution2010
no dont need to be torqued just a slight nip once they start getting tight say quarter of a turn gap size not to sure,what bhp u running?
try gapping plugs to 0.55
markd77
Rotherham, S Yorks
Cheers, really appreciate all the help.
Again, no idea on the bhp. Bought it decatted and it's an FQ340 so it will be somewhere around 350/360?
I'll have a got at 0.55 and take it from there.
stevolution2010
stevolution2010
if that doesnt work try 0.7 as u have more bhp than standard:)
Hi Mark and welcome along buddy!
Have you compression tested the engine???
Please update your User Profile to include your Location.
If the plugs are out then it will only take around 10 minutes at the most buddy.
It is well worth doing as you might just end up spending days trying to fault find because you were looking in the wrong place.
Just out of interest, how long have you had the VIII???
Have you inspected the ECU at all???
markd77
Rotherham, S Yorks
I've had it since April of last year.
The one other thing I have done recently that I forgot about was switch back to the CAT for the MOT. I ran it like this for a few weeks then got it switched back over. Could I have confused the ECU?
markd77
Rotherham, S Yorks
Right, I've gapped all the spark plugs to 0.7. I've also run a compression test on each cylinder. They came out at 11bar which I think is good.
One thing I did notice is that the bottom of the spark plus (around the screw thread) were pretty coked up and they've only been on a week. Could this be telling me something?
I've got my usual trek up to the north east tomorrow so that should tell me if gapping the plugs to 0.7 has worked.
Thanks for all the help so far.
