Replacing Evo 4 Front Sub Frame..??
L
lanosso
Can Someone Give Me Advice Please On Me Changing Front Driver Side Sub Frame...
I Would Be Greatfull..
What Is The Process For This Job..? Engine Stay In Etc????
Many Thanks
evoross
perth
:)if it's the same as evo v then you'll need to remove prop.exhaust,suspension arms ect,support gearbox underneath so you don,t strain top mount then subframe unbolts from body,i think8 bolts,hope this helps,engine doesn't come into it, i should know just finished strippinf front of car to overhaul:confused:
Many Thanks
