Rocker cover
Smokey
uk
I want to refurb my rocker cover, can you paint it or do you need to powder coat it?
all i did was paint mine an its been fine :)
youngy_315
youngy_315
kings lynn
i guess you can just paint it aslong as you use high temp paint. and the usual, sand down, grease remover, mask off parts you dont want sprayed.... you shouldnt need a primer either with high temp paint, but if you do use a primer, make sure that is high temp too!!
im sure someone will be on the confirm this.
i just used a can of ford diamond white that i had kicking around, coulld have done with laquering though cos its getting grubby now but its on the to sort list :)
quakes
quakes
wolverhampton
i would go for high temp paint if funds are low if not powder coat it, u'll get a smoother finish
South Wales
Ordinary motorpaint in a can will do you butty. No need for vht paint on rocker cover after all they don't airbrush rockercovers in vht paint.
Smokey
uk
Cheers guys, would i need to lacquer after i painted the cover?
yea i would, now ive had my grubby hands on mine a few times it needs a good scrub but if i had laqured it then the dirt would just wipe off :)
South Wales
As lee says it's easier to clean plus it won't show accidental marks as much and it will give more depth to the finish:)What colour do you intend painting it? if it's mettalic then you have to use laquer otherwise it will be like rubbing your hands across sandpaper:(
stevolution2010
stevolution2010
oldbury(WEST MIDLANDS)
never had my rocker cover off but i want to paint it also
what i wana know is are the gaskets rubber or cork as if its cork could break if its rubber ill get it off an paint it
It's a rubber one as is the grommet at the back where the breather goes in but this one can go hard and break when you try get it out so be careful with that one.
Also go careful with the plug leads as normal cos the metal inside can come out
stevolution2010
stevolution2010
ok cheers did u get any issues with oil leaks after is there a torque wrench setting for the bolts:confused:
Smokey
uk
Is there some sort of guide, do you need to rub down prime ect?:confused:
