Rebuild part's list
gooner8
gooner8
berkshire
as your all a helpful bunch:) started to get a list together of all the bits i need so if I've miss anything please let me no. Thanks Nick 1. Crank(got an e5 one)2. Piston's and rod's.(from el hopefully) 3.oil pump 4. water pump. 5. Full engine gasket set. 6 bearings(will let builder sort them out). 7 better cam's and pulley's(getting them from el hopefully). 8 lash's may as well as cam's are getting done. 9. Clutch once again may as well.10 bolt's maybe? Have i got it all?
stevolution2010
stevolution2010
oldbury(WEST MIDLANDS)
not sure u may need the flywheel from a 5/6 aswell
and if u dont already have them i rekon u will need the bigger brembo`s to stop it
cue b6lee!
good job im not working today isnt it lol
you getting a different block as well mate ? if you dont youll never cure the crank walk that the 4 engine suffers with.
you missed out water pump, head gasket (cosworth one is really good)
gooner8
gooner8
berkshire
yeah building a 4 block! O yeah water pump, won't a full engine gasket set have the head gasket in it?
get yourself a 6 block mate, much better. not much point re-building an engine without making it better :)
full set may have one, but not normally cos most people upgrade to an MR or cosworth/hks etc
Moray, 57N
Yep, ditch the 4 block and get something 5 onwards.
Depending on what power you're going for, we can judge what parts you require :)
gooner8
gooner8
berkshire
cant afford it mate, hopefully it will be better with 8 rods piston's and cam's:) i have thought this over and it seem's the only way. Thanks tho. Plus it will be nice to get a all most new engine.:)
gooner8
gooner8
berkshire
only want a safe 370ish think that will be enough for a 4 and me:)
gooner8
gooner8
berkshire
If you can get E5 blocks for £100 get me 20 of them you will be lucky to get a E5 onwards block for much less than £500.
that's what i was thinking not seen one yet for under £400, plus my engine is 13 year's old and 50k mile's and still run's fine? So a rebuild will only help.:)
Evo Parts Ltd
Birmingham
Hi mate
I have a set of acl bearings and balance shaft removal kit for an evo 4 brand new in the box.
£110 delivered
Also I will pm you a list of parts and price's you may require if you want me to.
Correct me if im wrong but did I not supply you a flywheel for your 4 a few months back, we met up in London whilst I was collecting other parts?
Regards
Tariq
gooner8
gooner8
berkshire
Hi mate
£110 delivered
Regards
Tariq
no mate wasn't me? Yeah pm away alway's worth seeing what's about. Thanks Nick
