Abs
Milesey
Hi guys
My abs light stays on pretty much every other day
It's an Evo 6 gsr are there any triggers for this other than the obvious?
Paul
Hi guys
Paul
I had greif with one of the sensors not picking up a signal. After a bit of fiddling to try and get it out the hub we gave up and left it. Drove car and found everything had returned to normal :)
Thing to do is short pins 1 and 4 together on the obd port under dash by steering wheel with a small bit of wire and count the flashes. I think the short flashes are tens and the longer flashes are units
Example 3 long flashes and 1 short one would be code 31
m7gsr
I think it's other way round Lee, long flashes are 10's
Jamie will prob be along at some point and put us right either way :)
m7gsr
Cool. I'm quite sure it is the long flashes are 10s, same on the impreza (classic)
