super unleaded
sweir
sweir
does anyone know if and where you can get 99 octane in N.I?? i cant seem to find it anywhere
You want shell Vpower or tesco momentum 99 failing that 97 super will be ok but you will need the car Re-mapped running on pure 97
sweir
sweir
yea lee i have been checking all tescos and shell garages i know of but no where sells it, im currently running on BP 97 seems to be ok, would just rather have 99 if i could get it
97 would be ok if your very carefull but you don't want to be driving it on boost cos your engine won't last long.
I highly recommend if you don't have 99 then you get the car re-mapped straight away cos even though it may feel ok I will be running very badly and failure will happen very soon.
EVOIV MJC
EVOIV MJC
You will struggle to get any higher than 97 anywhere here in n.I, the tesco momentum thing is only a uk I believe, there's nowt wrong with super 97 , if your car is going spot on with it then( if it ain't broke don't fix it):sad:
sweir
sweir
yea im thinkn of getting motec ecu soon so get it mapped then, i use 2 work in england and most tescos and shell garages had 99, just thought you get it over here somewhere
