Jonny IX
Group Buy Organiser
I washed the car today and dried it then parked it up in the garage and cleaned the interior as I was doing this I knocked the wipers on and they would not turn off so I switched the car off and carried on cleaning...then I turned the car on again to move it and the intercooler pump is whiring and has emptied out all the water all over the floor under the car.
Even when the car is off it is still whirring away???
So I started checking fuses on pulling out the Engine fuse (number 14 I think) cant check now as dark will check tommorow its a 20 amp fuse, the pump stops whirring but the car stalls without fuse.So have taken out fuse and switched off car is there another fuse box somewhere in the car or anyone know what this problem is and how I can cure it ?
Car is a 05 IX mrfq340
