2 in 1
  • Thread starter stevo-with-the-evo
  • Start date
stevo-with-the-evo
stevo-with-the-evo
Aberdeenshire
Hi all two questions in one really
1.when car is idling the oil light faintly flickers as soon as i give it any revs it goes out?
2.i intend on fitting my boost controller but the intruction is telling me to take vacum feed from the fuel pressure regulator?? is this wise or will it end up messing with my fueling?
any reply/ideas would be helpful
cheers
jamie@evotune
Co. Durham
Check the connection on the oil pressure switch and make sure its getting a good connection sometimes if they are corroded it causes them to flicker on idle. If the connection is good get the oil pressure checked just to be safe.
What engine oil have you got in the car ?
Dont tap into the fuel reg pipe if it comes off it will cause the car to run lean there is a pipe that goes down to the sas vac tank from the inlet manifold its in the center of the manifold on the back T into that one.
Bristol
first question with one is have you checked the oil level?
stevo-with-the-evo
stevo-with-the-evo
Aberdeenshire
ok cheers jamie where could i find the oil pressure switch??
The oil used was 5 - 40w
Bristol
the switch is on the back of the block, ruffly under the throttle body about half way down
if that makes sense
Looks like you are in capable hands here buddy with Jamie and Andy so I guess it's time for me to just do one! :cry: :whistling: :whistling: :whistling:
