Tarmac, gravel, snow fault???
Mickyturbo
Hi new to this forum, just bought an 06 55 plate gsr 260 and all 3 lights for the Tarmac, gravel, and snow are on all the time, is this a fault? Thanks
Wayne'o
Wayne'o
Yeah there should only be one on at a time,
What happens when you try to change the settingsfrom Tarmac to gravel to snow?
jamie@evotune
You have a fault with it get the dtc code read
m7gsr
Hi and welcome, sorry to hear but it is defo. a fault. As Jamie has suggested get the fault read
Mickyturbo
It doesn't do anything all 3 lights are lit at the same time, any ideas of where to get the codes read I'm in Leeds west Yorkshire, thanks guys
jamie@evotune
Read the flash codes bridge pins 1&4 out of the obd connector with a piece of wire and read the flash codes on the dash displayed by the ayc lights long flashes are 10's short flahes are 1's so 2 long flashes followed by 3 short flashes would be 23
Hi buddy and welcome to the Forum!!!
It may be a little daunting for you seeing as it is your first Evo.
If you would prefer, it may be better if you just take a drive as soon as you can up to Jamie, he is around an hour away from you.
He can take a look at it for you as well as give you some pointers too in the process.
No doubt he will have all the parts on the shelf should you need something replacing.
Keep us posted on how you get on.
rich_f
rich_f
hi guys i had this problem when i first picked up my 8 turns out where it was sitting for a while there was an air lock in the ayc system try chrcking the level of oil in the boot if its low keep topping it up smsll bit at a time.
