hi all, this is big spec tommi mak
The spec;
Currently running 477bhp
The engine is built for up to 800bhp covered 9k
HKS valve springs
HKS cam gears
HKS IC hard pipes
HKS cam belt
HKS 1.2mm head gasket
HKS 272 cams
Tial bov
ARP head studs
ARP main studs
Crower con rods
Wiesco 85.5mm pistons (with Teflon coating)
Eagle forged billet crank
Walbro internal fuel pump
Boosh 044 external fuel pump
ACL chamfered bearings
3mm lash adjusters
Boosh 1000cc injectors
2 bar map sensor
Titanium valve spring retainers
Ralliart thermostat
Ralliart radiator cap
Balance shaft removal kit
NGK iridium spark plugs
Custom manifold with GT3076 turbo
Slimline fan
4 inch intake with big K&N
Battery relocation kit
Custom 3 inch front pipe
Percision external waste gate 44mm
3 inch full mongoose*
3 inch decat
Vipec ecu (mapped by Mark Shead MA Developments)
AVCR boost controller
New standard radiator
APS intercooler
HKS turbo timer
Exedy twin plate clutch just fitted
Pf 2 piece discs
Brembo 4 pots on front
carbotech XP10 pads
Brembo 2 pots on rear
corbotech XP8 pads
5.1 brake fluid
BC coilovers stiffness, camber (front) height adjustment
Front and rear strut braces and boot brace
B&M short shifter
Ralliart mat set (not including boot one)
Ralliart mudflaps
Thanks for looking
The spec;
HKS valve springs
HKS cam gears
HKS IC hard pipes
HKS cam belt
HKS 272 cams
Tial bov
ARP head studs
ARP main studs
Crower con rods
3mm lash adjusters
2 bar map sensor
Ralliart thermostat
Slimline fan
3 inch decat
APS intercooler
HKS turbo timer
Pf 2 piece discs
carbotech XP10 pads
corbotech XP8 pads
5.1 brake fluid
B&M short shifter
Ralliart mudflaps
Thanks for looking
