irritating sound
ron23
norwich
Hello guyz..for 2days now ....been hearing some noise coming from the front.('am not sure if that is front wheels..tire rod or ball joints...can really hear it in lower speed...any ideas? And if it falls to those i mentioned how roughly will cost?
Thanks
Mid Wales
quite hard to diagnose something like that over the tinterweb mate, maybe get a vid up on youtube to give aus an idea.
stevolution2010
stevolution2010
oldbury(WEST MIDLANDS)
your best bet is to jack the front of the car up then once the wheel is off the ground put 1 hand at the top of the wheel in the centre the other hand on the bottom rock wheel forwards with the top hand and pull back with the bottom
if there is any play in it then its your ball joint 9times out of ten
then try holding the wheel i hand left side in the centre other hand right side in the centre
rock wheel again if theres any play from this could be track rod end or wheel bearing
if u try both of these and either gives u play in the wheel then u have a problem
if its not something u think u can do yourself then consult a mechanic
hope this helps:)
stevolution2010
stevolution2010
Thanks
does it happen in straight lines or when cornering what type of noise?
whurring,clicking or metal to metal?
does the wheel feel like its going to buckle under the car when turning?
ron23
norwich
Thanks guyz....at the moment i will try your suggestion stevolution...then i will update you both (stevo&sponners)
Thanks
ron23
norwich
Thanks
ron23
norwich
hope this helps:)
hey stevo...i did the things you told me..'am a bit happy bcoz' it went perfectly okay..it's all negative (thank God) i had a slight idea..i think its the running board..it's a bit loose..i will just try to sort that one...and it might stop the friction..at least it's only a minor...thanks to your adviced.....and to sponners..thanks as well
stevolution2010
stevolution2010
how about thanking me with a woot an u can say your finger slipped(hope toms reading this):whistling::whistling:
He has already given you a WOOT buddy, don't bleed him dry!!! :razz: :whistling: :whistling: :whistling:
