C
Colin
- edinburgh
said a need coil overs to Handel better for track days my a linement was already out before... Its realy out now tyres are have wire shown... do want to change them Intill it's lowered Evo 4 is parked now..Have you tried fitting these? Any pic of the height of the car with them on? Looks like you have a tiny bit of adjustment left.....id have thought it would have been on its arse tho with them on adjusted the way they are, were they off an evo 4?
Stressed out can't drive the car unless I sort this out or put the origanl suppenstion back on...
Ebay add said off an evo 4 with 40000 miles got them put them on and the evo is sitting way to high looking to comprese the spring them sort out the adjustment or new spring at lost end and need help
I couldnt tell you mate. Iv never heard of coilovers for off roading but iv only ever bought them to lower a car and never done any rallying. Bit baffling to be honest, does it sit higher with the standard springs on or is it higher with the coilovers on?
Hi andyGet back on to the fella who sold you them and just ask how low his car was sitting...or if he did rally. You say you want to lower it 13cm that 130mm thats a bloody lot, your wheels will be under your arches which will be no good for track days anyway. It looks like the rears have a fair bit of adjustment left in them so they'd probably drop enough for what your after but can see how you will do the fronts. How are you planning on compressing the springs?
